t_seane
Botswana
DJI Paladin Posted at 2021-7-1 20:02
Hi, thank you for reaching out and we're sorry for the trouble. Can you please confirm if you press the power button on the remote controller does it show any lights? Also, you may try leaving the controller on the charger to see if it will show any lights. If the said controller does not turn on even you leave it on the charger for about 1-2hours, I'm afraid that you may consider sending the RC and drone in for a full diagnosis. You can contact our support team to start up a ticket at https://www.dji.com/support as you are having an issue also on the gimbal of one of your DJI Mavic Mini. Please keep us posted. Thank you for your understanding and support!
Greetings, i have a similar issue but the light come on when i put it on the charger. It does the 1,,2,,3,,4 blinks then gets stuck on the full four bars for a few seconds then repeats the process again. left it on the charger for a few hours but when i removed it, it still refused to switch on. Can you advise? |
