P3KoYoT
Flight distance : 1846667 ft
Poland
DJI Stephen Posted at 7-5 21:06
Hello there P3KoYoT. Good day and thank you for reaching out. The DJI Mavic Air remote controller's control sticks are used to control the drone's orientation ( yaw ), forward /backward movement ( pitch ), altitude ( throttle ), and left/right movement ( roll ). The function that each control stick movement performs is determined by the choice of control stick mode. 3 pre-programmed modes ( Mode 1, Mode 2, and Mode 3 ) are available and custom modes can be defined in the DJI Go 4 application. The default mode is Mode 2. Thank you.
[view_image]
DJI Stephen Thanks for the explanation. I'm not a newbee and I know which mode I use.
Everything is set to Mode 2, I'm using same mode for all my quads. It happens randomly.
Regards
KoYoT |
