vg1
Flight distance : 1640367 ft
Poland
If I understood correctly:
high temperatures:
- the higher the temperature, the better the battery performance (max 60C),
- the higher the temperature, the lower the internal resistance,
- above 60C, the battery may be unstable,
- optimal battery temperature while flying is around 40C,
low temperatures:
- better not to fly at a battery temperature of 0C or less (reduces battery life),
- in frost, use batteries previously heated to a minimum of 10C,
battery charging:
- do not charge when the battery temperature is below 10C (shortens the battery life), warm it to a temperature of about 25C,
- the optimal temperature of the battery for charging is 25C-30C,
- temperature during charging 30C-40C. |
