KeyserSoze15
Hello. I got a DJI mini 2 drone for fathers day and was having a blast with it. Well today I did several flights and took pictures just like normal. Only when I connected the drone to my phone wirelessly to download the pictures/videos today it locked up halfway through the download. Ever since that lockup I can't get the drone to pair with the controller/phone nor can I even get it to turn off. It simply blinks fast yellow forever. When I go to shut it off with a push of the button followed by another longer push it never turns off. I had flown this around 40 times prior to this happening so I know how it is suppose to work. I looked around online and found others who had this issue as well. However many others found the problem to be with their SD card and they were able to use the drone if they removed the SD card from the drone. Mine however continues to not work after I remove the SD card, power everyoen off and then try to power it all back on and even manually pair the drone/controller again... No luck... I plan on calling DJI support on Monday but was hoping perhaps others might give me other things to try. There is no way I am the only person to come across this issue. I hope to get this thing back up in the air as soon as possible - Thanks |
