dr6583
Flight distance : 490627 ft
FB: GeoDrone4K Posted at 7-25 01:49
Hi,
Is the same bugs as before, nothing changed...
At 1.5km the SC is red in signal, there is lag when you re-pair aircraft with remote, the custom mode sticks still not working...
I have to agree. The range with the SC and my A2S is less than the range with the RC. At a little over 1000 ft. today (that's only 300 m) the signal bars turned red and flashed. I managed to get the signal back by adjusting the antenna, but really? At less than 2000 ft flying another direction the signal dropped completely. I don't think RTH automatically engaged. When I flew the drone a little closer towards me it re-established the connection with the SC but there was no indication that RTH was ever initiated, and I waited for it before taking manual control to give it time to get close enough to re-establish the connection, but it never did.
There were also lag issues, some happening as close as 1000-2000 ft.
The current firmware combination for the SC/A2S just doesn't seem to work well at all. I updated the firmware on the SC using the DJI Assistant 2 as instructed here. I chose the latest version ending .64. I'm wondering if a previous version would work better. Does anyone have a good firmware version known to work well with the A2S? The DJI Assistant 2 allows for installation of previous firmware versions.
Also, does anyone here use the AlienTec antenna mod on the SC? PM me if you want. |
