AntDX316
Flight distance : 3394731 ft
Bashy Posted at 8-13 23:19
I have the decent on my phantom cranked a little and coming down hard can end up being uncontrolled in the sense that it wobbles greatly, I believe this is something to do with the props catching up with the prop-wash, from what I read. No, I only upped the sports mode speed as per the NLD app, decent/accent rate to 10/ms etc, i think it was, no manual manipulation to the script was done, i.e. no tweaking of the numbers using the in-depth method or the method via Assistant, only used the settings provided in the NLD software.
SO, if you over do it, it can become unstable, this is why DJI adds limits, its not just for safety, it's for a stable flight too
No doubt it looks stable coming down but it does mean it's not recoverable. Like I said, in DIY (do it yourself) drones (before DJI) it always stabilize itself even with a descent rate going to terminal velocity (free fall). DJI didn't allow a higher decent rate is because it can overshoot the time it takes the drone to stop before hitting the ground being detected. This is the same as the climb. In normal mode it's supposed to stop when it detects something. Overshooting isn't good. If it's not for staying within the stopping limits then it's the stress placed upon the battery as more discharge is happening. Believe it or not, my batteries are not swollen. There should be nothing wrong with decending too fast if it can power up the motors before it hits the ground.
There are understandings in life that people develop around a narrative but things that fall outside the narrative, we are on our own so the more we know the better. I know at even 1mph on rollerblades I can get seriously injured. I know even doing 160mph+ in a turn, I won't crash on a motorcycle. |
