djiuser_cbMhPPG5SyPq
DJI Mindy Posted at 7-23 01:01
Thanks for the information. The battery may need to be replaced. Could you please send us the invoice or proof of your purchase to check it further? If the battery is under the warranty period, you can start a case through the link below and send it back. http://www.dji.com/support If not, you can purchase a new one. https://store.dji.com/shop/inspire-series?from=menu_icon&inspire-2-filterable-product-section=inspire-2-battery
Although my batteries were purchased on March 28, 2019 this particular battery was rotated with another one just for the Master Wheels, so very little rotation because the Master Wheels is very battery efficient. However, with the pandemic my business did not have much work hence my batteries did not see much work either and just sat in the battery station case. if you can access the battery cycle use you will see this to be the case.
I'm hoping that something can be worked out as I see this less of work abuse than some technical DJI TB50 glitch.
Regards,
Michael |
