FriedChicken_II
Flight distance : 721555 ft
1. Please don't ever do that 44% battery launch again. Please, this is a very common reason for losing your bird... Whenever the battery is lower than 90%, it is not a good idea to launch the bird. Unless you're doing really short flights like flying for just 50 meters.
2. You were flying in the canals, and the VPS (Visual Positioning System) reported a dangerously low altitude of just 1 feet before it was confirm landing. This is also a very common reason for losing your bird: The VPS takes over altitude reports against GPS when you're very close to ground.
See here:
4min 35s, GPS 16.1ft, VPS 3.0ft
4min 40s, GPS 14.1ft, VPS 1.0ft!
I think that at this point the vps altitude made the firmware think that you are going to land.
When you're this close to the ground / water surface, the VMU can be tricked. So DON'T fly your Mini 2 that close to water, that's all. Keep it at least a few meters up or it might dive into water at anytime. |
