Just curious once you link a smart controller to your mavic mini 2 can you not go back to a normal one. I have tried multiple times to link the original back to my mini 2 and pairing just times out. Any ideas does my controller need a update? Thanks in advance
TP-FPV Posted at 7-26 09:51
Are you also intiating pairing on the drone?
You can definitely switch back and forth.
Yes I turn the drone on. Then hold the power button for 4 seconds to enter pairing mode. Then I go into go fly app and click connect aircraft. It runs through tthe he whole 50 second and says pairing failed.
Ok everyone I figured it out the original controller needed to be firmware updated. Everything works now. I used DJI assistant 2 on my comp[uter and then it did another update once I got connected to the mini 2.
NVDroner75 Posted at 7-26 15:59
Hi there. We're glad that you already manage to isolate the issue that you experience. Please don't hesitate to reach us if you have other inquiries or concerns. Thank you for your support!
