UKMoose
Flight distance : 3657552 ft
Johnny_J Posted at 4-16 06:12
Don't use a diode. A 100-ish ohm resistor will limit the charging current. Measure the voltage across the resistor and you'll get an estimate for the charging current. (I = U / R)
Adjust the resistor value to your preferences.
Now johnny_j
Just follow up to your tip regarding 100 ohm resistor, well I've finally got round to trying it and I do have a positive result, if I fly a battery down to 55% my controller will be around 91%, now with the 100 ohm resistor in the circuit the controller was at 97%, sort of a result, thanks for the tip. |
