Not good
1653 17 2021-7-27
Dale 68
Flight distance : 338468 ft
I've owned my Mini 2 since 11th June 2021, and I turned up to a location Ive been wanting to go for a while, I get it all set up and I recieve this message, its never been crashed as ive hardly used it, not happy Screenshot_20210727-161052.jpg
2021-7-27
hunterws
Flight distance : 382536 ft
android or iphone?
have you updated the app since last flight?
(with a more concise post title, you'll get more attention)
2021-7-27
KlooGee
Flight distance : 16783757 ft
Refresh the firmware.  DJI support will likely ask you to do that anyways.  If that doesn't work, then contact DJI support.  They'll get you a new one within a couple of weeks.  When I bought the original Mavic Air a few years ago, it arrived direct from DJI with a broken sensor.  They replaced the drone quite quickly.
2021-7-27
Dale 68
hunterws Posted at 7-27 09:56
android or iphone?
Using Android, everything up to date.
2021-7-27
Dale 68
KlooGee Posted at 7-27 10:01
Not sure how to do that, but the camera was very hot so it's probably fried.
2021-7-27
hunterws
Where did you buy it?  They may be able to swap it for you if it was a local purchase ... maybe even online retailer will help solve your issues with an exchange.
Since the app update, seems all android users are having issues from minor to crashing, while the apple users are experiencing none of it.
That's why I asked which system, and knew before you posted you were an android user.
Getting highly suspicious with such blatant problems and they're quietly sitting on their hands.
2021-7-27
Bashy
Flight distance : 2354357 ft
Did you forget the gimbal protector, very easily done...
2021-7-27
Lucas775
Flight distance : 50642090 ft
Bashy Posted at 7-27 18:25
First thing that came to mind when said camera is hot.
2021-7-27
DJI Stephen
Hello there Dale 68. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please check if the firmware of your DJI Mini 2 is updated and if still the issue persist, it would be best to contact our DJI support team via http://www.dji.com/support to open a case and for a diagnosis on the said DJI Drone. We'll do our best to help you on this issue. Thank you.
2021-7-27
DubSound
Flight distance : 104459 ft
You can't refresh the firmware on Mini 2's thanks to DJI not allowing us.
2021-7-27
Dale 68
No, first thing I take off, I did it once with my Phantom. There is is no movement what so ever from the Gimbal even when I turn the wheel, it just get very hot
2021-7-27
Dale 68
hunterws Posted at 7-27 16:30
Taking it back to the shop I got it from today, hopefully I'll get a replacement.
2021-7-27
DowntownRDB
Flight distance : 1722 ft
Dale 68 Posted at 7-27 22:25
Hopefully, the shop has a liberal return policy.  Lot of the shops in the US are either 10 days or 30 days on returns.  Best of luck.
2021-7-28
hunterws
DowntownRDB Posted at 7-28 05:38
That is, without issues.  So, that holds true if you just change your mind because you don't care for the color.  When bad things happen, they should be there for you for a longer duration.
Gotta love the reply from the company above .... they'll do their best, that's reassuring.
2021-7-28
Mini2 Flyr
Flight distance : 4347785 ft
I can confirm the Downward Vision Sensor errors you are experiencing are due to a malfunctioning/broken co-axial cable. You will need to have your drone replaced.
2021-7-28
DowntownRDB
hunterws Posted at 7-28 09:51
Definitely not the most reassuring comment.  I think original poster's Mini 2 has a hardware issue that slipped through DJI's QA check.
2021-7-29
Dale 68
All sorted, got a replacement, from the shop  I bought it from,
2021-7-29
KlooGee
DubSound Posted at 7-27 21:40
EDIT:  whoops, I tested with the original Mini.... I haven't checked yet with the Mini 2...
EDIT 2: I see what you are saying.  That is an unfortunate decision on DJI's part.  Not cool.
picture below is the original Mini, not Mini 2
2021-7-29
