Bashy
Flight distance : 2354357 ft
Mobilehomer Posted at 7-29 09:20
How does the false horizon(the two short lines on either of the drone icon) on the map appear? With a lot of wind from the side, the drone can tilt too far for the automatic gimbal leveling to work.
Hold your Mini in your hand and tilt it and you will see how far it can be tilted before the gimbal can no longer handle it, at a guess, it seems around 45º.
My mates mini 2 was flying next to mine in 20+mph gusts and his was level @ 360º where mine was crook for around 180º, now whilst it is highly likely it being the wind that causes it to go crook, the wind should NOT affect the gimbal, can you imagine the wind speed needed to tilt that drone 45º and even then the gimbal wouldn't go crook, it would bottom out like it does on the Phantom 4,, again, try it, tilt it as far up to 90º and see what i mean by bottom out.
The idea of a gimbal is to make the camera level wind or no wind.
Folks said it was wind for mine too, my replacement says otherwise therefore, if you have a DJI AC where the gimbal is crook (tilted) then there IS something wrong, i.e.. calibration and if calibrating does not rectify it then it IS faulty. |
