Erdal YILMAZ
Flight distance : 7470 ft
Turkey
DJI Stephen Posted at 7-28 21:38
Hello there Erdal YILMAZ. Good day and thank you for the inquiry. The DJI Mini 2's Takeoff Weight is at < 249 g ( The standard weight of the aircraft (including battery, propellers, and a microSD card) is 242 grams. Actual product weight may vary. Registration is not required in some countries and regions. Check local rules and regulations before use. These specifications have been determined through tests conducted with the latest firmware. Firmware updates can enhance performance, so updating to the latest firmware is highly recommended. ). In addition, if accessories are mounted to the DJI Mini 2, it is recommended to enable the Payload Mode fro enhanced safety. Thank you.
Hello Stephen,
Thanks. I need to know the maximum weight Mini 2 can handle with the Payload Mode on. I live in Turkey and to register the drone, I need to declare maximum weight Mini 2 can handle officially. Since the takeoff weight is declared as <249 grams, the government takes that into account and does not register my drone.
Why I want to register? Because it is easier to request flight permissions when you have a registered drone. Please don't ask why Also, I am designing several LEGO spaceships on top of Mini 2, via snap adapter, to have some more fun and some of them are taking the weight of Mini 2 over 500 grams. I don't want to strain the drone just to have a little more fun
