kyalami
Flight distance : 17352513 ft
Sweden
Sean-bumble-bee Posted at 8-1 13:06
I doubt data is recorded in the .txt flight log after the drone disconnected from the controller.
In most of the log analysis that I have seen, here or elsewhere, if the connection was lost or became intermittent there were gaps in the data coinciding with the periods of lost connection.
Yes, you are right, however it would not cost anything just to check the .txt files. You never know what you might see. Is DJI the only one that can check the .dat files? If so, then, could not the .dat file be sent to them? |
