Who has this issue with their Air 2s / MA2 (Non-smart) controller?
352 4 2021-8-2
b9y
Flight distance : 704751 ft
I have this problem when using the right stick to fly forward. I push it forward, and there's slight feeling of toughness so you can keep it 'centre' when it's pushed up, although this "toughness" is only on the right hand side. When it's centre, dead centre, it seems to go to the left with the smallest movement.
The drone doesn't fly straight, because it's impossible for it to keep 100% straight. I will message DJI about this because it was the same on my MA2, but again they said the controller was fine.... Looking at it, measuring, it seems the hole in the controller ball is slightly towards the left and not placed accurately...like laser accurate. I wouldn't mind, but it's affecting flight.
DJI, we NEED the ability to tweak deadzones.
I see a mass recall incoming as I know a few people who have this issue.
2021-8-2
DubSound
Flight distance : 104459 ft
Have you attempted to calibrate the RC at all? This may help resolve the issue slightly until you can get a proper answer from DJI (Probably not much of an answer other than to RMA it to them probably)
2021-8-2
DJI Stephen
Hello there b9y. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please try to calibrate the said DJI drone and the said DJI remote controller to see if the issue will still persist? Thank you.
2021-8-2
jmb63
Flight distance : 7009439 ft
Calibrate the controller through the app..
But, if you had the same concern with the MA2, that almost indicates some specific way you, personally, are holding/using the sticks?
2021-8-3
b9y
jmb63 Posted at 8-3 05:01
I've troubleshot the "it could be me" thing and I can confirm my friend who owns both AND the M pro 2 has the same issue with the controller. I'll look at calibration, I must have missed that. Thanks!
2021-8-3
