Lore87
hi,
after a crash a low rear sensor broke. drone out of warranty. I'm waiting for the replacement.
The problem is:
the mavic 2 Pro turns on regularly, finds the gps signal and is green says "takeoff ready".
On the app comes the message of the rear sensor that does not work but with the x I close the message.
Well, I arm the engines, the drone rises 20cm and lands immediately ... in all cases.
I put the switch in S mode and the drone flies regularly in sport mode.
Now, I knew that even a broken sensor the drone had to fly the same ... where am I wrong?
Do I have to disable something in the submenus?
also because by saying to deactivate the sensors the drone does not take off anyway. Is there any way to disable the rear sensors?
