FriedChicken_II
Flight distance : 721555 ft
There's no such thing as "best speed for distance". why? because with wind's influence, the speed and efficiency change a lot!
The speedometer on your OSD is an absolute value, but the thing that matters is the relative value of speed between your drone and the wind, so how do you calculate a best speed for distance when there's no way to tell you the actual wind direction and speed in real time? Well, you simply can't.
The only thing that I know is that if you fly slowly in the air (which means a slow relative speed against wind), you get slightly longer flight time than simply hovering, due to many complex aerodynamic effects. Like if you can hover for 30 minutes then maybe you can fly slowly for 31 or 32 minutes. And that's about it.
Best speed for distance is generally the max speed of normal mode in windless conditions. If there're winds, you might still get the same speed but costing significantly more power to do so. |
