Jonathantuba
Flight distance : 197224 ft
DJI Paladin Posted at 8-8 20:00
Hi there. Thank you for reaching out. Once the DJI Mini 2 experience a signal loss, the unit will just hover in place once you set it on "Hover" under the Advanced Safety Settings on the DJI Fly app. In addition, if ever you cannot gain a signal then the unit is hovering and there is a low battery warning, the aircraft will determine whether the current battery level is sufficient to return home based on the current location. Please refer to the information below for your reference. Thank you!
DJI Mini 2 Manual: https://dl.djicdn.com/downloads/DJI_Mini_2/20210630/DJI_Mini_2_User_Manual-EN.pdf
Thank you for your help |
