Hello to all m600 lovers,
Looking for some fresh ideas on an urgent LB2 issue... Did several flights two days ago (M600pro, gremsy T7 and canon R5), absolutely perfect. Next day same location, same setup, impossible to get the video feed from the camera in go app...
Nothing has changed on the setup hardware or software config... Tried upgrading/refreshing all FW's, no help. The "video indicator" on the LB2 unit is solid red... According to Dji that would be "No supported video source is detected. Check that your camera’s output format is supported. Refer to the Appendix for a list of supported video formats." but the camera worked and has not changed...
All the rest works fine, the RC is linked, I have gimbal control, telemetry and can fly the drone. But not see what I am shooting, which I urgently need.
Thanks!
Edit: I also tried swapping the HDMI cable, no difference...
