heclectic
You should find stick control and effect is identical in both modes.
Simply, the difference between ATTI and GPS is that when in GPS, the aircraft's systems compensate for the wind (this is almost entirely at lower speeds and at hover it does entirely). This means when in ATTI, you must allow for the wind. With a littler practise, it becomes second nature to understand exactly what the wind is doing.
What you've to remember (because it's not immediately apparent to us), is that wind is a moving body of air and any machine in that body of air will move along with it at precisely whatever speed it happens to be moving. In fact, it isn't until you fly manually, that you realise just how much even light gusts of wind affect these small machines in flight. This is especially apparent in delicate, low speed manoeuvres... as it appears you've just found out... |
