sdharris
Flight distance : 384967 ft
I suspect they can get a fair amount of debug data over light bridge and by writing to the SD Card. They should have not problems from that perspective. But I do admit it is a hell of a lot of variables from the environmental perspective but the firmware is 1 and 0s, it's not magic, its sensor input, calculation, control movement.
What is peculiar is the delay in releasing the previous firmware as a new version for those affected by the problems. It depends on the method they use to patch the firmware. The packages are either going to apply code changes to specific part of the firmware almost like a series of hot fixes to computer operating system, or it contains the entire firmware.
They may be having problems getting the previous version to run reliably over 1.2.6/8, perhaps they tried it for a couple of weeks and decided it was taking too long so opted to crack on with the next full release and fix the problems in that. It also suggests that DJI employees and associates who often post on here, other forums and their tech support are largely kept in the dark as to what their engineering departments are doing.
Your could almost hear their head of engineering saying "You told them what?".
They're also having to balance that with the needs of their SDK developers as many have waited weeks for DJI to get them approved via Apple and for an SDK version of the firmware, thankfully that now seems to be progressing. |
