Huginn Kenningar
Flight distance : 49635259 ft
When they are worn off... if you take off/land from the ground instead of the hand or a nice surface like a clean table they'll wear off before (grass trimming, dust, little pebbles, etc).
Visually if there's any crack you must change them, but you can also pass your fingertips through the blades and if you feel there's any noticeable crack compared to a new one you should also change them. If they wear off to the point the motors have to increase the RPMs too much the app will tell you.
Don't know the exact flightime because I also fly the Mini 2 but I've flown more than 100 hours with the Air2S and are still like new, just clened them a liitle bit, never had a collision/trimmed the grass or hit anything solid.
