endotherm
Flight distance : 503241 ft
What you want to figure out is how much response you want from a unit of measurement while you are deflecting the stick. Normally the amount of deflection in X is the same as Y, but you can vary this. One axis represents the stick movement which can only be from -100% to 100%, and the other axis represents the amount of power applied.
If you look at graph A, you can see this curve is pretty flat against the X axis, then at the end, there is a massive jump to full deflection. In practice this means that you can push the stick 25% of the way across in the X direction, but it will only give you 1-2% in the Y direction. The next 25% to half way starts to pick up speed a bit, but the change might still only be 10% for a 50% stick movement. It's only when you get very close to full deflection that a miniscule input will give a massive proportional movement.
On the other hand, if you use graph B, you will get a massive response early on, and an almost imperceptable amount at full deflection. Of course these are extreme examples and you can make the curves less severe, and the response from the aircraft is less "twitchy".
If you want a steady camera pan from side to side, you would be looking at the curve in graph A. This way you don't have to be super accurate with the stick position. Anything up to half-deflection will only give a few percent of power, and results in a slow pan. You can deflect a bit more and it will slowly pick up speed. This will give you a nice smooth cinematographic pan. You are still able to pan at neck-breaking speeds by pushing it to 100% if that is necessary, but for most times, gentle movements are enough.
There are times when the other curve is desirable, for example if you want to apply it to forward or up, because you want it to be really responsive getting off the line from stationary, e.g. in racing.
In normal operation you will probably want different curves for up/down, forward/back, and rotate (pan). If you fly with the settings for a while you will develop muscle-memory and the imbalance of deflection to movement in every direction becomes second nature.
On the Phantom, you can only enter between 0.2 and 0.8, I think 0.5 represents a straight diagonal line. You won't be able to get anything as exaggerated as my example curves, but you can tend towards it, with lower values looking like option A and higher values looking like option B.
You can change the curve by either entering a number between 0.2 and 0.8, or clicking on the curve and dragging it up or down to make it flatter or curvier.
