GaryDoug
Flight distance : 1264639 ft
That shield/cover was on the GPS/IMU board. You would have to take the drone top cover off to access that part. The shield is under the board, so the board has to come off.... or at least raised up. It may be that the ribbon cable has to be unplugged, but you may be able to put the cover back on without unplugging the ribbon cable, which is held on with hot melt glue.
See the teardown video linked in post #2 at 3:59 to see the very quick removal, and at 7:56 to see a description of the board and a view of the location of the cover on the other side.
As always, use static discharge protection methods to avoid damage to the electrical parts.
