aeriallens
Well...not so fast. While it is true that YOU need to be aware of and avoid air traffic, the Cessna pilot may also have been in the wrong if the plane was below 500 feet as you seem to suggest.
Assuming that you were in the USA, and the Cessna pilot was not approaching a private field, and the Cessna pilot was not making an emergency landing, HE/SHE WAS MOST LIKELY FLYING TOO LOW. 500 feet above the ground was probably as low as the Cessna should have been. There are certain exemptions, of course, like those guys towing banners just offshore at the beach.
Title 14 of the Code of Federal Regulations, Section 91.119 of
the General Operating and Flight Rules, which specifically prohibits low flying aircraft:
• 91.119 Minimum safe altitudes; general
o Except when necessary for takeoff or landing, no person may operate an aircraft
below the following altitudes:
(a) Anywhere -An altitude allowing, if a power unit fails, an emergency
landing without undue hazard to persons or property on the surface.
(b) Over congested areas -Over any congested area of a city, town, or
settlement, or over any open-air assembly of persons, an altitude of
1,000 feet above the highest obstacle within a horizontal radius of 2,000
feet of the aircraft.
(c) Over other than congested areas - An altitude of 500 feet above the
surface except over open water or sparsely populated areas. In that
case, the aircraft may not be operated closer than 500 feet to any
person, vessel, vehicle, or structure.
(d) Helicopters - [etc]
So there you go. |
