DJidrones
Flight distance : 2113153 ft
Hello
I wish you the best of luck with DJI's technical service, it is the worst I have ever seen in my life. There are many cases of people who send in their products with a problem, they check it and tell them it's fine, when it arrives they test it and the problem is still there, others are told they have fixed it and when the owners test it the problem is still there (I have two friends that this has happened to) and there are other cases where they charge for the fix and the problem is still there (there are several cases on this forum).
You can only pray and cross your fingers that none of the above happens to you, maybe there is a time when they truly fix the problem and the product works properly and maybe that time could be yours. Don't lose hope
Good luck |
