Range decrease?
2861 35 2021-8-23
#ilovemymavic
Flight distance : 1121230 ft
South Africa
I never believed it, read on many forums that mavic mini users experienced severe range decreases after updates.I remember when I got mine about a year ago, I bragged and showed a friend I could easily fly from my house to his - about a mile away. So I tried again a while ago, there was a whole lot of updates in between. It would'nt even make it halfway there. So I ordered range extenders - you know, those yagi-uda type. Same thing. I even got on the roof - nada, it would make it closer, but still a few hundred yards away.
So I tried downgrading. Even used (distorted text) to downgrade all the way to v1. 0.2
Still doesn't help. I am hellbent on getting it the way it was. I bought it because it could do close to 4km. Now it can't even do 1km.
Of course I also did a lot of youtubing and research, learnt about setting it to 2.4ghz, selecting the best channel, manually, but that helps nothing. So I have come to the conclusion that those updates affecting the controller cause the problems.Because I can't downgrade that.. Even if I use (distorted text)
I was a happy chappy, but time has come to move on.. Not so happy anymore.. My next drone will NOT be a Da-Jiang Innovation.
2021-8-23
Porktree
Flight distance : 1118323 ft
I have sad news for your username.
2021-8-23
#ilovemymavic
South Africa
Porktree Posted at 8-23 06:02
You are right. Lemme correct it!
2021-8-23
ABeardedItalian
Flight distance : 1063107 ft
#ilovemymavic Posted at 8-23 08:06
Welcome to planned obsolescence, only fix is to buy a mini 2 but you might only get 6 months before it too is effected when they release the mini 3.
2021-8-23
#usedtolovemyDJI
South Africa
ABeardedItalian Posted at 8-23 08:17
I hear ya. I think I will save up for a while and get an a...l
I am done with Da-Jiang Innovations.
2021-8-23
K6CCC
Flight distance : 651683 ft
Most likely you are receiving an increased amount of WiFi interference.  It is only getting worse and worse.  Not likely related to firmware updates.  When I fly from my house in a sub-urban area in the Los Angeles basin, I can only get 300 meters or so in most directions, and about 100 meters in one direction before losing signal due to WiFi interference.  On the other hand, on a trip out in the desert with NOTHING around, I was routinely flying out 1,500 to 2,400 meters with good signals.  On the longest flight, my only limitation was a military base to the north and east, a mountain to the west, and a wilderness area to the south that I could not enter if the drone went down.  BTW, the longest flight was at night and I could clearly see the added aircraft strobes.
OmniSync helps, but the reality is that in a crowded RF environment, there is only so much you can do.
2021-8-23
#usedtolovemyDJI
South Africa
K6CCC Posted at 8-23 12:29
So my next understanding is maybe it has become more sensitive to WiFi etc. Would you suggest then I update to the latest or stay at an early version?
2021-8-23
Ph3onix
Flight distance : 2341886 ft
#usedtolovemyDJI Posted at 8-23 20:45
Hello, in those which concerns me the best version of DJI FLY for the Mavic mini and the version 1.1.10 I use it and I have no problem, with it I can exceed the 3.5km without problem if I wish in normal conditions (my mini is in CE version) while with the other versions I have always had connection problems, I know that some people will say that the app cannot improve the range of the drone but in my case yes (and I am not the only one looking on youtube the tests that were done with compared to the higher version) it is the version best suited to the mini 1 and the most stable I even have a smartphone with this version only for the mini 1 and another version for the mini 2 on another smartphone because it does not fit well with the 2.
This is a personal opinion but that does not prevent you from doing a test and reverting to another version if it does not suit you.
On the other hand I did not make the last update of the mini 1 the V01.00.0600 because many people had problems with it and in addition I saw that it is not possible to go back one times install so I can not certify the result with this version
2021-8-23
#usedtolovemyDJI
South Africa
Ph3onix Posted at 8-23 22:37
Ok..So I update to the latest.
2021-8-23
DJI Tony
Hi, there. We are sorry for the inconvenience you've come across. We recommend that you use the latest version of the firmware.
The shorten of  flying distances may caused by various factors such as signal interference, obstacles and so on. Here are some ways helping you check it. When you perform a flight, please make it in open areas without shelter and signal interference. And make sure there are no obstacles between the remote control and your drone. In addition, when flying your drone, it is better not have your back to it or the signal might be weaken. It is recommended that you pay great attention to the antenna orientation making sure it stays parallel with the aircraft and constantly adjusting it during your flying.
If the issue still persists, please feel free to contact us at any time.
2021-8-23
Ph3onix
#usedtolovemyDJI Posted at 8-23 23:44
Warning I think you did not understand maybe a bad translation. I did not update because of some problem with version V01.00.0600
I did not tell you to make this update, it is your choice if you do
2021-8-23
Mashroomhut
Flight distance : 2760791 ft
Poland
I must agree with Ph3onix. I am using the same App Version and I didn't do the RC Firmware Update. I am also using an exclusive mobile device for the Mavic Mini (huawei p10 lite). I am very pleased to use my drone with this configuration.
What I've noticed is the newer app versions need more processor power and perhaps my mobile devices (my secound MD is Huawei p30 lite) are not strong enough to run Dji Fly properly causing the range dropouts.?
2021-8-24
#usedtolovemyDJI
South Africa
Mashroomhut Posted at 8-24 00:14
So, balance me here.. I am slow... The remote control version you use is v1.1.10 or the application on your cellphone? Is that the latest?  The drone version?
2021-8-24
Ph3onix
#usedtolovemyDJI Posted at 8-24 00:36
OK
The configuration of my Mini 1 currently is as follows
Drone version and (Firmware V01.00.0500)
DJI FLY version is version 1.1.10
The latest version of DJI FLY and version 1.4.8 but it's a real disaster and only problems
The latest version of the Firmware for the Mini 1 is version V01.00.0600 which is not really for the drone but for the RC, is with this version some people have had problems and more with this version impossible at the time current to downgrade to a previous version in case of problem.
2021-8-24
Reguzz
Flight distance : 60375420 ft
Indonesia
Yup, RC firmware v01.00.0600, after updating you cant revert it back to old firmware, because I;m the victim here lol
2021-8-24
Mashroomhut
Poland
Ok. My stable configuration:
Drone and RC Firmware is: V01. 00.0500
DJI Fly App Version 1.1.10 on Huawei p10 lite.
I don't fly far away (often), but it gives me more confidence flying up to about 500m in semi urbanized area. In the same area flying with my secound mobile device - Huawei P30 lite and  DJI Fly v 1.4.8 I menage to fly barely 300m away.
2021-8-24
Ph3onix
Reguzz Posted at 8-24 02:33
Do you have any problems with it like a reduced scope for example?
2021-8-24
#usedtolovemyDJI
South Africa
I'm also screwed.
2021-8-24
Reguzz
Indonesia
Ph3onix Posted at 8-24 04:28
So far so good. For RC performance, what I feel is still the same as the previous firmware in my case.
BTW, I'm using fly app v1.4.8 build 1185.
2021-8-24
K6CCC
Lots of comments since I Was last here yesterday.  I generally update both firmware and app versions shortly after they are released..  That applies to most devices that I have (not just my drone).  I personally have not seen any real range changes related to app version or firmware updates.  It sucks near my home because everyone and their brother has various devices that share the same frequencies that we use for our drones.
2021-8-24
Ph3onix
made all the same the test never know it can work, if you are andoid it is easier to install different version and go back
2021-8-24
Ph3onix
Reguzz Posted at 8-24 05:46
Wow!   the worst version released by DJI so far, even if this version '1185' and a little more stable than the '1120' but not much more.
2021-8-24
Ph3onix
K6CCC Posted at 8-24 05:47
You fly with version 1.4.8, and which smartphone do you have?
2021-8-24
K6CCC
Ph3onix Posted at 8-24 06:00
Mini (original) and controller have the latest firmware - sorry, it's not in front of me, so I can't look at what version that is.  App version is 1.4.8 on a Motorola g7 power phone, a Galaxy tab-A tablet, and a #$%^& iPhone 8.  I generally fly with the tablet, but at times with the android phone.  I only flew once with the &^%$# iPhone when I first got the drone last year in order to make sure it worked.
2021-8-24
Ph3onix
K6CCC Posted at 8-24 06:47
Ok thank you, and you have no problem with version 1.4.8 with android devices?
2021-8-24
#usedtolovemyDJI
South Africa
Ph3onix Posted at 8-24 05:51
We are talking about the remote here.. Cannot downgrade.. If you are on the latest you can't go back. .tried on Mavic assistant. You can upgrade and downgrade the apps or the drone firmware, but not remote.. I think the range decrease was there.. Why else would they not allow one to downgrade?
2021-8-24
K6CCC
#usedtolovemyDJI Posted at 8-24 08:12
Normally with computer stuff, when a downgrade is not allowed it is because file formats have changed - the new software can read the old file format and will write the new format, but the old software can't read the new file format.  Don't know if that was the case here...
2021-8-24
K6CCC
Ph3onix Posted at 8-24 06:54
Not that I have noticed.
2021-8-24
dr6583
Flight distance : 490627 ft
have you ever thought of the possibility they don't want us to fly as far anymore
2021-8-24
Tuxtard
Flight distance : 9975610 ft
Serbia
It's probably not related to the drone or updates, but to the environment. It's not just the matter of your neighbors getting better and stronger WiFi. Interference is getting stronger every day with each new 5G mobile node and each new Starlink satelite. Also you will get more interference during summer because all the leaves around moving with the wind create a static electricity which will degrade your signal.
2021-8-24
K6CCC
Tuxtard said (in part):
There are a number of devices operating in the same spectrum as our drone operate on, but neither 5G mobile, nor Starlink are using the same chucks of spectrum that we are.
2021-8-24
Geebax
K6CCC Posted at 8-24 12:12
Quite correct. Just about any device that transmits uses the same section of the radio spectrum as we do, everything from garage door openers, to wireless doorbells, security cameras, baby monitors - the list goes on forever.
2021-8-24
dji_MODDER
Flight distance : 73209 ft
Solution is simple, take a look @ Drone-hacks
2021-8-24
#usedtolovemyDJI
South Africa
Geebax Posted at 8-24 15:14
So occusync is the way to go..
2021-8-25
Geebax
#usedtolovemyDJI Posted at 8-25 23:14
All the Occusync does is add additional forward error correction to the return video signal from the aircraft. That makes it more readable, but you still have 2 other channels that you can lose in the process.
2021-8-26
Parkway Production
Flight distance : 247201 ft
How is it going Ladies and Gentleman,
I bought my Mavic mini gen1 back when they came out, I own a M300 and a Autel EV2P as well.
I love my mini and I always use it in tight spaces when making videos....Yesterday I  tested again the range issue with signal interference at the lake Dec 24 2023....it was not busy 10 people max in the entire park.
The issue came up again.
I read through the suggestions and I came across Drone Hacks .com and wanted to ask if that has worked for anyone in here and if the possibility is given to downgrade and restore range issue without causing other issue or malfunctions.
appreciate your feedback
2023-12-25
