donewright
Flight distance : 13448 ft
India
I believe DJI has removed the limitation now. I updated to the latest version of the Android app available for download from their site (not the Play Store version) - V 1.5.0
After installing it, the altitude limit was set to 500m. However, just like when it was set to 15m, you can't change it (the slider is still grayed out but it's at 500m instead of 15m) but you can change the auto-RTH altitude (that slider is unlocked).
DJI, if you're reading this, could you revert the functionality back to the old way where the altitude slider wasn't grayed out and allowed you to pick a max altitude below between 0 and 500m. Right now, it's fixed at 500m which means you can't limit it to anything below that. It's great that the restriction is lifted but offers less control than before since you have to keep an eye on the altitude reading and manually ensure you're not flying above the limit. |
