Bashy
Flight distance : 2354357 ft
GaryDoug Posted at 9-5 06:32
Yes that is what I said as was clearly stated: "No matter the method, when the compass error message appears, it NEVER prevents me from launching." NEVER.
I am trying to find out why almost nobody ever reports the source of magnetic interference, including the OP. I am not convinced that we know all about this type of anomaly. My test results do not show the problem so there must be something else that is the cause. It could be something in addition to the iron nearby.
I just wanted clarification is all
Because they are not aware of the cause, I was aware when it happened to me, it was taking off from my car sunroof, I am sure Labroides will remember it...
The OP has a Mini 2 which ALSO has the power switch on the bottom. I would test with an actual Mini 2 but I have given mine away.
True, but then that's back to my theory, maybe he turned it on too close to those railings, that's where my money lays...
As you're testing with a mini and not a mini 2, the test is null and void really, but then we don't know how different they are inside I spose.
But also, you should be recording each and every test and get them on youtube so we can see it from start to finish, it would be quite interesting, certainly to me
I AM flying farther away than the OP certainly. And one source of interference was an 3' IRON crowbar 1" thick directly under the mat. I could not have done more.
Thats something at least, the problem we do have is, your not in the same position as the OP, that's where you need to do your test, like I said, we don't know how much if any, magnetic field is being given off by those objects, again, you need to use an app that measures magnetic fields and get it all on video
You do not have to take the chances. I am doing that for us all so don't worry about it. At this point my Mini is very expendable since I never use it.
Thanks
As for your last statement, I have ALREADY done that at least 3 times.
Ok then, well all we can ascertain from this is either;
- the mini is not affected by a magnetic field
- the magnetic field isn't strong enough to affect the mini
- there is no magnetic field
- It's a mini, not a mini 2
Should have recorded the lot lol would have been interesting.
How about you go an find a old of railings like in the OP's video and see how you get on, please, record it
