djiuser_HtuQuZ1XMwkz
Flight distance : 354386 ft
Austria
Bashy Posted at 9-1 22:38
Inspect the props for any nicks/cracks, run your fingers along the edges, if you find any, replace it or them.
Make sure the motors spin freely and feel the same when testing by hand.
Make sure the gimbal is straight when in the air, even in 20mpg gusts, it should be straight whilst in a hover.
Hi Bashy,
Props were fine, one had a small scratch from the wall.
So, I replaced them all with new screws.
Gimbal calibrate always and it keeps the horizon.
Also it hovers good and up and down gimbal button works without problems.
No errors at all and no scratches on drone, except the one on already replaced props.
So, I guess I am fine.
I also used mini camera and inspected absorbers. None is broken on gimbal.
Thank you.
