Labroides
Flight distance : 9991457 ft
It's quite difficult to get anything really useful from your flight data.
Here's the best I can come up with.
At 17:25.3 your GPS reception dropped out completely.
The GPS receiver had no GPS signal at all after that.
The position data stops updating from then on.
Speed data relies on GPS, so there is no speed data after GPS was lost.
We can see that you were 2213 ft from home and high enough to clear any obstacles in the vicinity.
The drone was flying SW but and after a little wandering around, you were flying mostly south until 20:20 when you started wandering E and NE.
Flying at full speed for that time the drone would have covered nearly 3000 metres, which would have taken it well south of where you were.
The drone is likely to have ended up somewhere in the vicinity of Dungarvan Golf Course, but could be a bit east or west of there.
The flight data doesn't show any landing as signal was lost when the drone would have been approx 880 ft higher than the ground below it.
In the attached map, the vertical line shows a southerly path for 3000 metres from where signal was lost.
The drone would have ended up somewhere a little north of the end of the line, but it's not possible to tell how far east or west of the line it would be.
Sorry, but that's all that can be calculated with any certainty.
