DJI Paladin
Hi there. Thank you for reaching out. You may perform the circle under the Quickshot mode of your DJI Mini 2. The Aircraft will circle around the subject at the preset direction and a radius based on the current distance with the subject, once finished, the aircraft will stop recording. If you want to continuously do a circle, you may create another circle video and you may edit those videos (combine) using 3rd party editing software. Thank you for your valued support! |
