Père Vianney
Flight distance : 4009403 ft
steamship Posted at 9-6 04:04
Whilst in Photo mode, down in the bottom right of the display you should see Storage, Format and EV. Below Format is the current photo setting, and to change it, just tap on the Format area. That should then display the options available, which are JPEG and J+RAW.
Can you confirm if you have tried that and what options are available there? Can you also confirm what version of the App you are using (found in the About section of the Settings menu)?
OK, I've found J+RAW where you told me, thank you!
Problem solved, thanks to all of you who answered my question |
