Yaros1
Flight distance : 19981112 ft
I have been flying my DJI MA2 for almost a month now and was interested in its range capabilities, so I decided to do a range test, not my first one with the drone, I did a lot of range tests in the past with other drones both DJI and non-DJI.
This one went, let's say, pretty bad, but it might have been much worse, I was very lucky, let me explain why!
I took off from the roof of my apartment building, where I was standing too, and flew into the distance, keeping VLOS most of the time, the signal was going worse and worse but after re-adjusting the antennas it was better, long story short I flew 6.3km away from the Home point ignoring the Return-To-Home prompt! Always, ALWAYS bad idea! Just don't, it exists for a good reason, to notify you when you need to return back! But I didn't, I continued going and when I couldn't go further I started returning and started noticing that I don't quite have enough battery to return! That made me nervous but I had a car with another person that could drive it so who cares, I thought, if needed I will drive to a safe place to land, and do that! Well, if that would be as easy as I thought I wouldn't write this... when the battery was as low as 20% I hopped into the car and went to the location (I thought) the drone was a BAD IDEA, I lost signal immediately and the drone started landing, not returning to home because the battery was on 8%! I was in the middle of a pretty big town, not knowing well the streets... When I approached the location, went out of the car I finally got RC signal. The drone was on 1% battery hovering near a hotel I don't even know, "that's not good" I thought, of course, it wasn't! I tried to look at the map and figure out where to go, I did, but the drone was already on 0% battery, I was holding the stick up as it was above some street with people! In its last milliamps available in the battery I managed to fly 30 meters before it depleting and landing pretty safely near me with a lot of people looking, not good!
So what I'm trying to say here:
- Don't go away from your home point until you find a good location to emergency land, and definitely don't go with the car while the drone is in the air, even if you're not driving the car yourself, as the signal as well as the VLOS will be lost.
- If the drone says that you should return then do it!
- Take wind into account
- Only do a range test in a controlled environment, without cars or people ideally in some open field area
- And of course, don't land your drone in areas you don't know
This definitely taught me a lesson, I will try to fly safe from now on!
Pls don't send hate to this...
Thanks for reading
