P4P Remote continues to beep after all known reset options HELP
1147 13 2021-9-11
pastorjared2
Flight distance : 127740 ft
Im having a beeping problem with my P4P Remote.
I have tried to resolve the issue by:
1. Holding down C1, C2 and record button.
2. Downgrading firmware on remote
3. Making sure the firmware is current
4. Remote Controller Calibration
All have led to continued beeping.
The only way to keep the beeping from happening is going to the Remote Controller Calibration and pressing start. But if I go through the process of calibration and click finish, the beeping starts back up again.
Any help would be great.
2021-9-11
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Can you please confirm if you were able to connect to the aircraft even the remote controller is beeping continuously? Also, could you please provide us a video sample showing the issue for better assistance? Please keep us posted. Thank you!
2021-9-11
pastorjared2
Yes I am still able to connect the drone and fly it even with the continued beeping.
2021-9-12
embayweather
Flight distance : 556667 ft
I had a similar problem when my control sticks were not correctly aligned.
2021-9-13
Edward J Smith
Flight distance : 1852408 ft
I am having the same problem.
2021-9-13
pastorjared2
DJI Paladin Posted at 9-11 20:21
Yes, I can confirm that it beeps continuously even after the remote is connected to the drone.
2021-9-15
ELPoupa
Flight distance : 1069826 ft
hi, you can try to do a factory reset on both P4 and remote then link them again.
2021-9-16
pastorjared2
ELPoupa Posted at 9-16 13:55
how do you do a factory reset on the remote?
2021-9-16
ELPoupa
pastorjared2 Posted at 9-16 13:56
And for the P4 you need to connect it to your computer you will be able to reset it using dji assistant
2021-9-16
ELPoupa
ELPoupa Posted at 9-16 14:11
[view_image]
And to link it again
2021-9-16
ELPoupa
let me know if your remote is working again
2021-9-17
DJI Paladin
pastorjared2 Posted at 9-15 07:58
Thank you for your response. Kindly please try to reset the remote controller as ELPoupa stated on post #7 to see if that works. If the issue persists, kindly please send us a video sample showing the issue. Please keep us posted. Thank you.
2021-9-17
dcap
the only time i have this is if you power up the radio with the joysticks not in the default position.
2021-9-18
Edward J Smith
Edward J Smith Posted at 9-13 06:48
I guess I have to take it to the repair shop for a fix ( I hope). Because none of the other steps have sovled the problem.
2021-10-6
