fansc524f944
Flight distance : 1723117 ft
In the Phantom series and with the Mavic Pro when you are flying in the POI Intelligent flight mode and hit the pause button, you then have the ability to roll the aircraft left and right. This ability was lost in the Mavic 2 Pro. When paused in POI mode and you attempt to roll the aircraft will not move. This maneuver is very useful in situations like cell tower inspection or other circumstances when your aircraft is on the opposite side of the POI and you would like to safely and easily bring it back around to the side that you are on manually. This maneuver is also very useful when you need to fly the POI pattern between the guy wires of a structure. Is there any way to make this change manually in the settings or get it included in an upcoming firmware update?
