Sime27
Flight distance : 64429 ft
hallmark007 Posted at 9-16 02:05
Its nota bug . Dji recommends you do a preflight check and knowing which mode you will be in is pretty much standard. Common sense seems to be very uncommon around here yourself excluded ;+)…
I totally get it taking off in normal mode , But for 1st time flyers that complete a pre-flight check that are worried about the drone speeds etc , Switch slider to CINE , screen displays C mode then they would presume the drone is in CINE mode.
Like this weekend i was teaching my so how to take off , so thought CINE would be where to start
At best i'd exspect a warning -unabale to take off in this mode-or somthing along them lines , Least then the pilot knows and is prompted to switch slider to Normal
