Flycaster
After making sure you have all your gimbal isolators in place (check visually from underneath on the gimbal plate.
OK, with the props off, power up the AC, outdoors if possible, and let it fully boot, aquire sats. home point, etc.
Calibrate the gimbal, and if this completes successfully,then start recording, and watch your video feed, gently moving your AC in rotation/tilt. all good?
Then start the motors and repeat test, checking vid quality. Still all good?
Install the props and repeat testing.....and let us know... |
