DJI Stephen
Hello there DroneVid1. I am sorry for the trouble this has caused and thank you for reaching out. Using the Vision System of the the DJI Mini SE, when GPS is unavailable, the Downward Vision System is enabled if the surface has a discernable surface and sufficient light. The Downward Vision System works best when the drone is at an altitude of 0.5m to 10m. If the drone's altitude is above 10m, the Vision System may be affected, so extra caution is required. Thank you.
