Sean-bumble-bee
Flight distance : 15997 ft
Whilst the time taken may be undesirable you have the offer of a replacement drone, is that not a satifactory outcome? Admittedly it might be more favourable if there were a repair centre in the Philiippines to which you could return it.
I have stripped a mavic 2 that spent several days in the sea, the only salvageable components were the plastic body parts and perhaps the camera shell so I suspect that your 'repaired drone' will actually be a new or new condition replacement.
A battery disconnection in flight will obviously stop the log recordings on the phone but it appears that shutting the App down will do the same. I just tried the latter indoors, with the drone hovering and then looked at the logs from the phone using CsvView. The logs, DAT and .txt, terminate with the App shutdown and a 'new' set start with the rebooting of the App. There was no loss of control of the drone and the drone continued to hover and or follow any commands given, all unpreturbed, but the drone was close and indoors.
Out of doors and at distance I am not sure what the outcome would be but would be surprised if it was immediately disasterous.
I have the recollection that loss of the App or, perhaps, not having a phone connected to the controller, can limit the distance and height to which the drone can be sent but what would happen if the drone was already at height and or distance?
I certainly have had an App and or the phone crash / reboot whilst flying out of doors but, although it was unnerving, I do not remember the details expect that it is likely that the drone was not far away or high, so there can not have been any significant consequences. I do not remember the model of drone but it was a DJI drone.
I do not know what would happen if the drone were at height and or distance but I would be surprised if the loss of the App had any immediate detrimental consequences, it might mean that the drone can not be commanded to move further away or climb but I would guess it can be made to return using the control as per normal. After all am M2Z can RTH if the connection with the controller is lost.
However. if the App does crash then the drone would continue to record a DAT to its own memory. Depending on what action you took on recovering the drone, i.e. washing with fresh water and or alcohol, the DAT on the drone might still be available, if the drone could be powered up etc., but I would not be inclined to try and power the drone up for fear of damaging anything else. I believe Phantom 3's store the drone's DAT on a mSD card 'glued' into the mainboard but I saw nothing similar when I stripped the Mavic 2 so I guess the drone's memory is a chip.
Even if the drone could be powered up and the onboard DAT recovered only DJI can read the DAT in the drone, it is encrypted.
