how do it works
393 4 2021-9-26
BWJ
Denmark
How do M2 measure distance to an objekt, when you do a quickshot circle ??
2021-9-26
The Saint
Flight distance : 5902228 ft
not sure exactly your question but i'm going to go out on a limb with a broad reply which is, in general, all distances are measured using gps.
2021-9-26
hallmark007
Flight distance : 9827923 ft
It doesn’t, you set parameters and as long as you don’t touch sticks it will maintain these parameters.
2021-9-26
Turbo1ed
Flight distance : 1322582 ft
When doing a circle, it doesn't need or do measure distance, it just tracks the object with the camera and keep it centered in front while flying sideways, making a circle in the process.
2021-9-26
GaryDoug
Flight distance : 1264639 ft
Like Turbo said above. But I think it goes a bit farther. I think it calculates the radius by noting the rate of angle change required to keep the target in the center of the screen. More angle = closer target. I have no proof of that theory however ;-)
2021-9-26
