SheMunkee
Flight distance : 15407 ft
KryosChaos Posted at 9-28 10:42
OK... there are no specific height restrictions but you are flying in the USA. You are legally not allowed above 400' AGL. if you are launching at 3600 feet MSL you can go 400 feet to a height of 4000 MSL.
I have no idea why you were thinking 5000 feet. The drone may be rated to fly that high if you are talking MSL but not AGL. That also might be an Operating max, similar to submarines that have a crush depth, above a certain height you were are doing nothing more than beating the thin air and the drone really won't respond as there is not enough air to work on.
HI there. Thanks for reaching out with your concerns. I understand there are some things you are unclear about. Let me try to explain again.
I will refrain from acronyms to improve clarity.
My takeoff altitude was over 9k feet above sea level. I was attempting to takeoff when I received a warning. I was not in flight. My drone had not taken off when the message was displayed. I couldn't take off until I accepted a warning that I agreed that my warranty with DJI was void.
My inquiry is to why my DJI would display a message that a warranty would be void when trying to takeoff at altitudes above 3000m above sea level (takeoff, means drone is on the ground, not in the air) when the drone manufacturer clearly states that the maximum takeoff altitude is 5000m above sea level. Anything higher and the drone is not rated to operate in the thin air.
My flight did not exceed 70m, which is 229 feet above the ground, which is below the legal ceiling in the US of 400 feet.
A perfectly legal flight within the bounds of both federal and local laws, and within posted operating specifications of the DJI Air2S |
