Montfrooij
Flight distance : 2560453 ft
DAFlys Posted at 10-5 01:04
Certainly something to look into, there's a couple of ways to do it, if its part of a circle then rough cut and then clean up with the router on a pivot, or make a template to use a bit with a bearing in.
Yeah, it is just the corner. But quite a large cut.
The cutting point is 22cm from the corner, so it is quite a bit.
I have seen furniture makers using them indeed for this.
I will ask around in my 'circle of acquaintances'. 2 of them are experienced woodworkers, so they should be able to get me going. |
