DJI Wanda
Hello, there. To quickly move on to the troubleshooting steps. Would you please check the things below first?
1. Please check whether the gimbal protector or the gimbal buckle has been removed before powering on the aircraft. If the gimbal motor is overloaded for this reason, please remove the gimbal protector or the gimbal buckle and then power on the aircraft again.
2. Whether an aircraft is powered on when it is placed on an uneven surface or when a foreign object has jammed the gimbal, the gimbal motor may become overloaded.
3. Please unfold the frame arm before powering on the aircraft to prevent the propellers on the rear aircraft arm from obstructing and jamming the gimbal.
4. Whehter this issue only occurs in Sport mode
Please keep us updating. |
