fans5b25584c
Flight distance : 24012 ft
It seems like its always been DJI policy to not allow access to mission and log files, and the M300 continues that tradition.
If you make a mission like you want, export the mission as a KML, then open the KML with a text editor, you will be able to see the waypoint functions that you're after have been exported.
When you export a mission as a KML, then re-import it on the same machine, do the waypoint actions make it back properly? I've never tried that.
I have been able to come up with a way to export mapping missions to KML on a computer, then load them on the M300 to fly, but they don't involve any waypoint actions, so I can't help with that.
I have used generated KML files as a way to get around the single autofocus problem with mapping missions, but it's very tedious.
Mapping missions are inherently simpler than the discreet waypoint missions.
Moving a complete mission from one controller to another is an interesting problem. I'll have to look at an exported KML to see if there is anything like a machine serial number that could be causing your problem.
It's certainly a brute force workaround, but an option to find the mission file would be to make an image of an entire M300 controller file structure on a computer using the USB port, then define a single mission, then make another image and find what's been changed. Assuming the mission file is stored as a single file, and you can find where the new file is, you might be able to transport just that file to another M300 controller, put it in the same place, then see if it shows up.
The bottom line is I have never understood why DJI encodes log files and hides mission files.
Just silly.
Think of how nice the world would be if you could just read log files without having to send them to someone else and copy and edit mission files on another computer. Someday somebody else will make devices as good as DJI, but without the smoke and mirrors of files.
I'll be standing in line to get one |
