eEridani
Flight distance : 7006224 ft
DJI Mindy Posted at 10-22 01:17
Hi there, please calibrate the compass of your mobile device and the drone. And please also check the environment to avoid metal interference. You may also test in a different area. And please control the aircraft to fly a short distance (above 20 meters) for a check.
Just flew the drone through two batteries, a controller compass recalibration, and the issue persists (still there).
I've also discovered the SCREEN RECORDING function does not close the file properly; and a user must view the file on the controller before it is actually saved into the Movies/Screen folder. This may be why I am losing screen recordings.
This PC\Smart Controller\Samsung SD card\Screenshots
This PC\Smart Controller\Samsung SD card\Movies\Screen
Today - copied the folders above to my desktop and the screen recording I just did was NOT in the files copies. Nor could I find it on any of the controller folders. When I used the controller to view videos stored on the device, the recording was not there the first time through the menus, but the second time I opened videos it was there. It also then showed up in the Movies/Screen folder and could be copied to the desktop.
1.4.12 is certainly much more defective than 1.4.8, which I will to revert to.
1.4.12 is not usable.
