Flight Logs - Txt Files - Smart Controller
14755 4 2021-10-23
djiuser_IxOaRD4i3n8r
Flight distance : 1088960 ft
What are the steps to retrieve the txt. files for the flight logs for the DJI M300 RTK?
2021-10-23
hoss_
Flight distance : 166168 ft
Extracting Flight Logs from a Smart Controller to SD Card:
1. Insert a SD Card into the SD Card port on the top of the Smart Controller
2. Turn Smart Controller on if it is not already powered on.
3. Select “NO” when asked if SD card should be set as default storage location.
4. Select menu by clicking on 4 dots in the bottom right.
5. Select “File Manager”
6. Select Internal Storage
7. Select the folder “DJI”
8. Select the folder “com.dji.industry.pilot”
9. Select the folder “FlightRecord”
a. All Flight Records are stored within this folder as txt files.
10. Tap and hold a .txt file to select it, check boxes to select multiple (newest flight logs are located at the bottom).
11. Select Copy from the bottom menu after selecting all files you would like to copy.
12. Select SDCARD from list
13. Select a folder on the SDCard which you would like to “paste” the files to or simply select “paste” to copy the files to the root of the SD Card.
14. Turn off smart controller and eject SDCard, connect SD card to computer with an SD Card reader to import files to computer.
2021-11-11
fans5b25584c
Flight distance : 24012 ft
Are those files in straight, readable text, or encoded?
You can also transfer files in and out by loading either the Android DropBox or Amazon file storage apps, then using a WiFi connection.
Google Drive is theorhetically possible, but it takes a bunch of other dependancy apps and processes.
2021-11-11
R_CAPTURE
Flight distance : 10305 ft
hoss_ Posted at 2021-11-11 16:26
Hello,
I'm trying to find all the alert messages that appears on top left corner in flight.
Could you tell me in witch folder i can find this log? Because I have a "intrinsinc calibration data expired" message when flying the P1.
And how to read the .txt log files? because it's like this :
GmcONIA9PFzHw1gpPLLPoqev3ytAH5KO3S/CJpMsylg=
35kyjVfwBJgytCi6KM5Vug==
doa12N3u8xHwg8w3p+MhPA==
yr+rGw8f9kTgKYwyiO5eBg==
wlqTN9tGYyTkBUhaF/rhIQPv69pmL4iDyAAUml2ltBN8ffiauMimxFR9efgt4YWn
2023-9-22
msinger
Flight distance : 236647 ft
R_CAPTURE Posted at 2023-9-22 02:25
Hello,
You'll need to use an application that can decrypt them like Flight Reader (https://www.FlightReader.com).
2024-1-19
