fansfe82067d
If users follow the instructions in the getting started manual exactly as stated there's no real problem. For me, seeing Chinese at the outset without an obvious way to switch to English was a worry. But if I had simply done what i was told, I would have been fine. There's a moral there somewhere..,
The video that I am currently uploading to YouTube doesn't really attempt to show quality as such - it's mainly related to explaining the orientation lock setting, which is essential to be aware of. Also I did a quick test walk with horizonsteady on, then compared width of image with HS on, RS on, and all off, then a brief test of the zoom feature.
Next thing I will explore will be how well it works on my Falcon gimbal which I recently got for the Action 1. The point? Well, to provide horizon lock at 4K and the other modes you get with a gimbal. If it works, the Action 1 will be relegated to dashcam duties.. With the magnetic system it should be the work of a moment to pop the camera unit onto the little gimbal using the magnetic prong adapter pre-attached to the gimbal, when wanting to shoot in that style. The Action 2 really does merit a bit of lateral thinking to get the most out of it - it stimulates creativity.
