GaryDoug
Flight distance : 1264639 ft
I have found that in an often used spot in my front yard, 30 feet is not quite enough to insure precision landing since there are many trees around the spot. I now lift to about 50 feet, just above the tree tops and get good results. I also get better results by using the black/yellow side of the landing mat in daytime instead of the orange/white side, which I use at night.
Edit later.... Lab though I meant better GPS, but that's not what I meant, just a fuller image at that height. Sorry for the confusion.
What I have noticed is when I lift to only 20-30 feet, sometimes the drone comes down in the trees (without an intervention). Going higher usually results in two corrections, one higher until it gets down to about 20 feet then another correction to place it on the mat. Only the last correction is noted in a message onscreen. This makes me wonder if the drone saves multiple images.
