christianunger
Austria
DJI Wanda Posted at 2021-11-1 05:08
Hi, there. Sorry for your inconvenience. Please kindly know that the product you are consulting is a third-party accessory. The performance of the RSC2 is closely related to gimbal load. As for the functioning of the other third-part accessories, we are not knowledgeable enough to know. Maybe you can refer to the physical weight of RCS2 plus your camera and then consult the corresponding professionals. If there is anything else need my help with, please feel free to talk.
@ Wanda maybe the question was not clear enough:
Can the RSC 2 bottom screw mount support the weight of the gimbal + camera or will the screw mount break?
This has nothing to do with the "third party accessory", as it does not matter if you mount the gimbal on a boomstick or on a coconut with a screw attached to it.
Or in another question:
Can the gimbal be carried by holding it only at the DJI extension grip that comes with it? Same issue, no third party thing involved.
@ OP I've been using the RSC2 + Panasonic S5 on the Gimboom, no problems so far, but I'd also like to know if the gimbal screw mount actually supports this.
